April 30, 2026 at 9:51 am
benjamin
SubscriberHello,
We are looking for best practices regarding migration of large legacy SpaceClaim file libraries fromÂ
.scdocto.scdocx.Our customer has several years of existing SpaceClaim data and wants to avoid manually opening and re-saving every file.
Questions:
- Is there a supported batch conversion method for converting large numbers of
.scdocfiles to.scdocx? - How should assemblies/external references be handled during this migration?
- Is there a recommended workflow from Ansys for customers with large existing datasets?
- Is the Windows-preview gonna be working in later versions in combination with SCDOCX files?
Any experience or guidance would be appreciated.
May 5, 2026 at 8:55 am
Devendra Badgujar
Forum ModeratorHello Benjamin,Â
Thanks for reaching out. I will check and get back to you on this.Â
DevendraÂ
May 15, 2026 at 6:44 am
benjamin
SubscriberHi Devendra,
Any idea when we can expect a response? The customer is currently stuck with the transition to the latest version of Spaceclaim.
May 18, 2026 at 4:34 am
Devendra Badgujar
Forum ModeratorHello,Â
You can use Converter.exe from C:\Program Files\ANSYS Inc\v261\scdm to convert large number of scdoc to scdocx.Â
Let me know if this helps based on your first 3 questions.Â
Windows preview should work the same for .scdocx as well.Â
DevendraÂ
May 18, 2026 at 7:13 am
benjamin
SubscriberThank you very much, I will try this and let the customer know!
6540
1311
