January 9, 2025 at 2:48 pm
breg
SubscriberSpaceclaim offers the opening of .rsdoc files from Designspark Mechanical, which uses the same core User Interface and functions but is developed independently.Â
Now from Version 6.x in 2023 onward, Designspark has moved to a new file format (to accomodate changes in parasolid AFAIK): .rsdocx
How can these files be read or imported into Ansys spaceclaim?
January 9, 2025 at 3:25 pm
Forum ModeratorI assume you've tried opening the file? The newer format isn't visible in the "full" version, but I don't know what will be supported in 25R1.Â
January 9, 2025 at 3:47 pm
Forum ModeratorCheck Discovery, I can see the reader in the "full" version.Â
January 10, 2025 at 12:17 pm
breg
SubscriberFound the solution myself by try-n-error:
Copy the file and rename extension to: .scdocx
Ansys developers might consider to offer opening of rsdocx files directly in the future.Â
January 10, 2025 at 12:19 pm
Forum ModeratorOr use the newer geometry tool? There's a reason I suggested using Discovery.Â
January 10, 2025 at 12:30 pm
breg
SubscriberHow would the geometry tool help me to work on rsdocx files?
The situation underlying this thread is that I put several hundred hours of work, over years, into Designspark modeling ;-)
January 10, 2025 at 12:36 pm
Forum ModeratorBecause that's how you read the other (rsdocx) format into the Ansys tools.Â
January 10, 2025 at 12:41 pm
breg
SubscriberOk, understood.
I prefer to use the UI that is close to the one I know.Â
And it turns out - it happens to use the same file format, only with a different extension. -
January 10, 2025 at 12:43 pm
Forum ModeratorThat's fine - Ansys are CAD agnostic in that we've got readers to most CAD platforms. You'll just not see them all in the Student version.Â
January 10, 2025 at 1:02 pm
breg
SubscriberOk, why not - what sense does it make to hide these functions from people whom Ansys wants to win as future customers?
January 10, 2025 at 1:37 pm
Forum ModeratorHide what functions? If you mean the readers, it's because many require third party licences - those aren't Ansys property and aren't free.Â
January 10, 2025 at 1:45 pm
breg
Subscriber-The function here is: Read and work on .rsdocx files from Designspark
-And the hiding: only after changing their extension. -
January 10, 2025 at 1:51 pm
Forum ModeratorWhich is in Discovery.....Â
January 10, 2025 at 2:29 pm
breg
SubscriberDiscovery has its own file format not compatible with DSM.Â
But it’s a one-way-street anyhow, as SC files do not open in DSM even after renaming the extension.ÂLeaves the question: Why is Spaceclaim still included in the Ansys portfolio?
January 10, 2025 at 2:36 pm
Forum ModeratorBecause it's still being used. We have geometry tools that were last updated well over 10 years ago in use, eventually they'll stop working or be replaced with the current versions but that's for a user to determine.Â
5669
1890
1419
1304
