December 5, 2023 at 10:40 am
Sa-aadat Parker
SubscriberThe editor I am using to edit *.k files has a commenting keyboard shortcut. This works well with well-known programming languages. However, It does not recognise Ls-Dyna syntax. Does anyone know which language the Ls-Dyna script is based on? Which language uses a '$' sign to comment?
December 6, 2023 at 4:29 pm
Jim Day
Ansys EmployeeLS-DYNA keyword file syntax is not associated with any standard programming language.
January 22, 2024 at 10:50 am
william shane
SubscriberThere is no universally accepted programming language that uses the syntax of an LS-DYNA keyword file. run 3
- The topic ‘Re: LS-Dyna k file syntax’ is closed to new replies.
Ansys Innovation Space
1057
1051
965
942
