April 10, 2024 at 1:01 pm
sa-aadat.parker
SubscriberAs I refine my mesh I keep getting the error in the title. This is run on a HPC. As I refine my mesh I get this problem. My coarser meshes run but the solutions are not satisfactory. I have a spherical charge of 4g with a 325 mm stand-off distance in free air. Below are some traces which are equidistant from the charge mass but taken in different directions. The air block size is a cube with a side length 500 mm and have three planes of symmetry. I start the traces at 0.2 ms. The pressure is in MPa.
April 11, 2024 at 11:51 pm
Reno Genest
Ansys EmployeeÂ
Unfortunately, Ansys employees can't answer this on the public Forum. Hopefully, other users can chime in.
Reno.
April 12, 2024 at 9:07 am
sa-aadat.parker
SubscriberHello Reno,
For interest why are employees not allowed to answer? Is it technical, national security or something else?
April 15, 2024 at 1:50 pm
Tonmoy
SubscriberProfessor Parkar,
I suppose you are an academic customer. Reach out to the ANSYS account manager of your university and they can help you to sort out this problem. Thanks!
April 12, 2024 at 10:17 pm
Reno Genest
Ansys EmployeeHello,
If you are a commercial customer, you can create a support case and we will be able to help you:
customer.ansys.com
There is no way for us to tell the application or the customer on the Forum and so we cannot help with blast or any potential military applications.
Reno.
- The topic ‘Re Error forrtl: error (78): process killed (SIGTERM)’ is closed to new replies.
