November 11, 2023 at 1:56 am
utkarsh.patel
SubscriberHello,
I have input PSDs for 60 minutes worth of testing but I want to generate a response of my structure for a total of 180 minutes. How would I do this in Ansys.
Do I need to convert my PSDs all the way down to time domain and then calculate it back just so it covers and gives data back for 180 minutes worth.
Appreciate any insight to this.
Thank you
November 15, 2023 at 2:11 pm
danielshaw
Ansys EmployeeWhy is the exposure time important? Are you attempting to evaluate the fatigue life? If so, you can use the Mechanical Fatigue Tool and specify the desired exposure duration. The FT will calculate the fatigue damage for the full exposure.
November 15, 2023 at 7:06 pm
utkarsh.patel
SubscriberHi Daniel,
I am not trying to find the fatigue life but rather wanting to find the effect of the run that would be on my system if it ran for a longer period of time. Wouldnt that make a difference to the given PSD inputs or it will change if it had to run for a longer than given time.
November 15, 2023 at 7:41 pm
- The topic ‘Random Vibration Analysis Repeat sequence’ is closed to new replies.
