April 9, 2024 at 6:40 am
abankusomari
Subscriberpleasse how can i plot a graph of the radial and tangential flux density of the air-gaps of a 3D magnetic gearÂ
April 11, 2024 at 8:25 pm
HDLI
Ansys EmployeeHello Ebenezer,
    You could build two new expressions in field calculator to get Br and Bt. In the field caculator, you can doÂ
    Input > Quantity > B
    Vector > XForm > ToCylindrical
    Vector > Scal? > ScalarX, to get Br
    We have Scl : ScalarX(ToCylindrical(
,offset<0mm, 0mm, 0mm>)), you can click "Add" button to add it into "Named Expressions" for Br. Â Â Â Â As same as that we do, select ScalarY for Bt. After that, you can plot or get results for Br and Bt in field results.
HDL
- The topic ‘radial and tangential flux density’ is closed to new replies.
1306
