Question Regarding Topology Optimization
    • jmcclos8
      Hi, I am simulating a large pressure vessel in Ansys. The two baseplates in the cut out are heavy and I was hoping to Topology Optimization to notionally lightweight the parts while minimizing stress. However, I have an issue with my optimization region and I am unable to determine what the issues is. I have attached a picture of the model. Any help would be much apperciated. Thanks!
    • Aurojyoti Prusty
      Hi Jacob,
      Can you switch the optimization to some other metod other than density based (such as level set based) and check  ?
      Please refer the below video to setup your model correctly for topology optimization.
      /courses/index.php/courses/topology-optimization-using-ansys-mechanical/lessons/topology-optimization-of-a-bell-crank-lesson-1/
      Thanks,
      Aurojyoti
      • jmcclos8
        Hi Aurojyoti,
        I tried the other optimization schemes. The optimization region is still not well define. Do you have any idea what may be causing this?
        Thank you for your assistance!
  • The topic ‘Question Regarding Topology Optimization’ is closed to new replies.
