January 23, 2025 at 3:55 pm
hasbydz72
SubscriberHello,
I am a student currently using the Ansys Student version to support my learning in engineering subjects. I would like to confirm a few things regarding the software:
- Does the license for the Ansys Student version expire after a certain period? If yes, how long is the license valid?
- What steps should I follow to renew the license or re-activate the software after the license expires?
- Are there any additional requirements or costs involved in continuing to use the Ansys Student version after renewal?
Thank you for your assistance. I look forward to your response!
January 23, 2025 at 4:16 pm
Forum Moderator1: Yes - it's covered in the same place you downloaded it from. Typically the licence is valid for a year and may later be extended at our discretion by an extra 6 months but see 2 below.Â
2: Uninstall, download the new version and reinstall. The fully licenced versions (eg Teaching, Research & Commercial) has a separate licence manager & file; the licence is often for a year but works on most older versions of the code.Â
3: No, it's still free for learning use. The other licence terms stand, and are covered in the T&Cs.Â
- acces to path ‘session_files’ is denied error
- Fluent and Rocky DEM coupling in Ansys student
- unexpected license problem; exiting. hit return to exit.
- ANSYS 2024 R2 Student License Manager Error
- Ansys Student 2025 R1 – Ansys Discovery did not install
- No FlexNet Publisher (FNP) license found for feature HPC Parallel.
- Ansys Electronics Desktop crashes when trying to set the steel type in RMXprt
- Workbench application not showing up after installing Ansys Student 2024 R2
2778
965
841
599
591
