July 3, 2024 at 1:02 am
JooJaehoon
SubscriberHello, everyone
I'm researching about break-away simulation using static structural tool
Slip occured between two component when external force occured, and it got new static equlibrium condition after slip
In this state, how force applied at interface? static friction? dynamic friction? or other force?
In addition, I have curious how ansys static structural calculate friction force at interface
I attached visual explanation data for your understand.
Thank you
July 5, 2024 at 3:31 pm
John Doyle
Ansys EmployeeThe code uses columb's friction law to enforce resistence to sliding.
Please refer to Section 13.174 of the MAPDL Theory Manual for formulas and more details. Â 13.174. CONTA174 - 3D 8-Node Surface-to-Surface Contact (ansys.com)
July 10, 2024 at 8:33 am
JooJaehoon
SubscriberThank you for applying!
I will check that page
- The topic ‘Question about friction force applied at interface after slip’ is closed to new replies.
- BackGround Color
- Contact stiffness too big
- Element Birth and Death
- Python-Script to Export all Children of a Solution Tree
- Which equations and in what form are valid for defining excitations?
4597
1495
1386
1209
