July 3, 2024 at 1:17 am
sme8
SubscriberHey,
I use an embedded high-Q analyzer in the FDTD module. Essentially, I use ring-down to estimate the quality factor of ultra-high Q factors. However, I realized that the Q factor it calculates is highly dependent on the source settings. For example, I set all the parameters the same for two simulations and only modified the wavelength of the source. I found that if I set my source wavelength to 700-900 nm, the quality factor is different from another simulation with a wavelength of 740-760 nm. Assume my desired resonance occurs at 750 nm. Please be informed that and the resonant wavelength does not change with different source wavelengths. I use an auto non-uniform mesh for my simulations.
I also modified the time domain properties of my source to have a very narrow band signal in the frequency domain (consequently wide in the time domain) near my resonant wavelength, and again, the Q factor changed dramatically.
What do you think? Which one is more accurate?
Thank you for your support and help.
July 8, 2024 at 4:22 pm
- The topic ‘Q factor calculation-Duplicate’ is closed to new replies.
