September 25, 2023 at 4:17 pm
Muhammad Danial Haziq Azizan
SubscriberMy question is how to plot the graph for resonant (a.u. vs wavelength), not the (a.u. vs frequency). Which part I need to change. Urgent..Tqs
# Q analysis
# This script calculates the quality factor from
# the slope of the decaying envelope.
# Input properties
# make plots: make plots of signal, envelope, slope, spectrum
# 1 for yes, 0 for no
# number resonances: number of resonances to look for
# Output properties
# f0: vector of resonant frequencies
# Q: vector of Q factors of resonances
# delta_Q: error in Q factor
# Tags: resonator high q analysis quality factor
# Copyright 2012 Lumerical Solutions Inc
# simplify input variable names by removing spaces
number_resonances = %number resonances%;
make_plots = %make plots%;
min_filter_width = 1; # min width of filter in units of resonance FWHM
max_filter_width = 6; # min width of filter in units of resonance FWHM
filter_width_test_points = 20;
zero_pad = 2^16; # fft zero padding
# Note fft zero pad should be a power of 2,
# and larger gives more resolution in the
#frequency domain.
for(N=0; (N+1) <= nx*ny*nz; 0) {
N=N+1;} # up to the sum of # of monitors = (nx*ny*nz)
# get the monitor data for the first monitor
t = getdata("t1","t");
field0_t_Ex = pinch(getdata("t1","Ex"));
field0_t_Ey = pinch(getdata("t1","Ey"));
field0_t_Ez = pinch(getdata("t1","Ez"));
# do fft to frequency domain for all monitors
w = fftw(t,1,zero_pad);
field_w = matrix(length(w),6*N);
for(i=1:N) {
mname = "t" + num2str(i);
for(j=1:6) {
if(almostequal(j,1)) { component = "Ex"; }
if(almostequal(j,2)) { component = "Ey"; }
if(almostequal(j,3)) { component = "Ez"; }
if(almostequal(j,4)) { component = "Hx"; }
if(almostequal(j,5)) { component = "Hy"; }
if(almostequal(j,6)) { component = "Hz"; }
if(j > 3.5) { extra_factor = sqrt(mu0/eps0); }
else { extra_factor = 1; }
if(havedata(mname,component)) {
field_w(1:length(w),6*(i-1)+j) = 2*extra_factor*( (1:length(w)) <= (length(w)/2+0.1)) *
fft(pinch(getdata(mname,component)),1,zero_pad);
# find resonant peaks, including all monitors
f_spectrum = sum(abs(field_w)^2,2);
p = findpeaks(f_spectrum,number_resonances);
f0 = w(p)/(2*pi);
# find quality factors
# reserve memory for results
peak_spectra = matrix(length(w),number_resonances);
peak_filters2 = matrix(length(w),number_resonances);
# calculate slope of decay using 40-60% of time signal
tp1 = round(0.4*length(t));
tp2 = round(0.6*length(t));
t2 = t(tp1:tp2);
log_field_all = matrix(tp2-tp1+1,number_resonances);
Q = matrix(number_resonances);
delta_Q = matrix(number_resonances)+1e300;
# loop over each peak
for(i=1:number_resonances) {
# find FWHM of peak
peak_val = f_spectrum(p(i));
continue_search = 1;
for(p1=p(i)-1; (p1>1) & continue_search ; 1) {
if(f_spectrum(p1)<=peak_val/2) {
continue_search = 0;
} else {
p1 = p1-1;
for(p2=p(i)+1; (p2
if(f_spectrum(p2)<=peak_val/2) {
} else {
p2 = p2+1;
if(p1 < 1) { p1 = 1; }
if(p2 > length(w)) { p2 = length(w); }
FWHM = w(p2)-w(p1);
for(filter_width=linspace(min_filter_width,max_filter_width,filter_width_test_points)) {
# calculate the filter for the peak
peak_filter = exp( -0.5*(w-w(p(i)))^2/(filter_width*FWHM)^2 );
# inverse fft to get data in time domain
field2_t = 0;
for(mcount=1:6*N) {
field2_t = field2_t + abs(invfft(pinch(field_w,2,mcount)*peak_filter))^2;
field2_t = field2_t(tp1:tp2);
log_field = log10(abs(field2_t));
# calculate slope and Q from the slope of the decay
# estimate error from the slope
slope = (log_field(2:length(t2))-log_field(1:length(t2)-1))/
(t(2:length(t2))-t(1:length(t2)-1));
slope_mean = sum(slope)/length(slope);
slope_delta = sqrt( sum((slope-slope_mean)^2)/length(slope) );
Q_test = -w(p(i))*log10(exp(1))/(slope_mean);
delta_Q_test = abs(slope_delta/slope_mean*Q_test);
if(delta_Q_test < delta_Q(i)) {
Q(i) = Q_test;
delta_Q(i) = delta_Q_test;
# collect data for final plot
peak_spectra(1:length(w),i) = f_spectrum * peak_filter^2;
peak_filters2(1:length(w),i) = peak_filter^2;
log_field_all(1:length(t2),i) = log_field;
# output summary of peak results to script window
?"Resonance " + num2str(i) + ":";
?" frequency = " + num2str(w(p(i))/(2*pi)*1e-12) + "THz, or "+num2str(2*pi*c/w(p(i))*1e9)+" nm";
?" Q = " + num2str(Q(i)) +" +/- " + num2str(delta_Q(i));
Q_matrix=Q;
Q = matrixdataset("Q");
Q.addparameter("lambda",c/f0,"f",f0);
Q.addattribute("Q",Q_matrix);
Q.addattribute("dQ",delta_Q);
spectrum = matrixdataset("spectrum");
spectrum.addparameter("lambda",c/(w/2/pi),"f",w/2/pi);
spectrum.addattribute("spectrum",f_spectrum);
# plot the results
if (make_plots) {
# plot signal and envelope for first monitor
field_t_Ex = invfft(pinch(field_w,2,1));
field_t_Ex = field_t_Ex(1:length(t));
field_t_Ey = invfft(pinch(field_w,2,2));
field_t_Ey = field_t_Ey(1:length(t));
field_t_Ez = invfft(pinch(field_w,2,3));
field_t_Ez = field_t_Ez(1:length(t));
plot(t*1e15,field0_t_Ex,abs(field_t_Ex),field0_t_Ey,abs(field_t_Ey),field0_t_Ez,abs(field_t_Ez),"time (fs)","field envelope");
legend("field (Ex)","envelope (Ex)","field (Ey)","envelope (Ey)","field (Ez)","envelope (Ez)");
# plot the slopes of the decaying fields
plot(t2*1e15,log_field_all,"time (fs)","log10(|field(t)|)","Decay for each resonance");
# plot spectra
p1 = find(w,0.8*min(w(p)));
p2 = find(w,1.2*max(w(p)));
f = w/(2*pi);
plot(f(p1:p2)*1e-12,peak_spectra(p1:p2,1:number_resonances)/max(f_spectrum)
,"frequency (THz)","Arbitrary units","Spectrum of resonances");
plot(f(p1:p2)*1e-12,f_spectrum(p1:p2)/max(f_spectrum),peak_filters2(p1:p2,1:number_resonances)
,"frequency (THz)","Arbitrary units","Spectrum and filters");
September 25, 2023 at 5:02 pm
SubscriberThen, what means by these codes to plot the resonant? why need to multiply 0.8 and 1.2?
# plot spectra
September 26, 2023 at 2:06 am
Dev
Ansys EmployeeHello, this is simply to set the axis limit. For eg if you change value from 1.2 to 1.8 the X-axis limit will incease to the right side. This wont affect your result.
Regards
Devika
September 25, 2023 at 6:23 pm
Dev
Ansys EmployeeHello, Can you share mode details? device under simulation and whee you accure this script?
September 26, 2023 at 2:00 am
Dev
Add the following lines at end of the script. You can plot the result in wavelength.
plot(c/f(p1:p2)*1e9,peak_spectra(p1:p2,1:number_resonances)/max(f_spectrum)
,"wavelength (nm)","Arbitrary units","Spectrum of resonances");
plot(c/f(p1:p2)*1e9,f_spectrum(p1:p2)/max(f_spectrum),peak_filters2(p1:p2,1:number_resonances)
,"wavelength (nm)","Arbitrary units","Spectrum and filters");
Note: When you use Forum next time please try to share more details. The more details you write the faster you get a suggested solution.
September 27, 2023 at 12:06 pm
SubscriberCan I know who is an expert in this topic? To find the Q factor with the existence of resonant which means calculate the Q factor based on resonant wavelength divided with FHWM. I really stuck using this software
September 27, 2023 at 12:57 pm
Dev
Ansys EmployeeHello Muhammad,
If you are using an academic license, through this forum you can ask questions and reach out to Ansys. Our support team replies most of the questions.
You can find equation and more details here. Quality factor calculations for a resonant cavity – Ansys Optics.
If you are new to using FDTD siftware,
You can refer this manual to learn more about the software: FDTD product reference manual – Ansys Optics
I recomend to take free course on FDTD: Ansys Lumerical FDTD – Learning Track | Ansys Courses
Thanks and reagrds
Devika
- The topic ‘Q analysis script understanding’ is closed to new replies.
6034
