June 30, 2023 at 2:44 pm
Sterling Butters
SubscriberGreetings,ÂI am trying to "check the box" for a number of parts in the structure tree. Using the recording feature of the API, I get the ViewHelper.SetObjectVisibility class/method. Trying to apply this to my existing selection yields nothing though - code below. How can I toggle the parts based on my existing selection?Âselect_bodies = []for i_body in GetRootPart()GetComponents():ÂÂ Â if i_body.GetName().Equals(""): Â Â Â Â select_bodies.append(i_body)Â# Change Object Visibilityselection = Selection.Create(select_bodies)visibility = VisibilityType.ShowinSelectedView = FalsefaceLevel = FalseViewHelper.SetObjectVisibility(selection, visibility, inSelectedView, faceLevel)# EndBlockÂ# Change Object Visibilityselection = Selection.Create(select_bodies)ViewHelper.HideOthers(selection)# EndBlock -
July 3, 2023 at 2:12 pm
Aniket Chavan
Forum Moderator  if i_body.GetName().Equals(""):    select_bodies.append(i_body) ÂÂAre you checking bodies with blank name? -
July 3, 2023 at 6:50 pm
mjmiddle
Ansys EmployeeThere are several problems in that first section:
- You forgot a dot (".") between GetRootPart() and GetComponents()
- A body is not a component. Maybe this was just a naming convention you were using in your script, because you can turn on/off visibility of components the same way as bodies. But you could have just as well named your variable i_component instead of i_body to be more clear, but it's just a variable name. However, if you intended to get bodies, you can get all bodies this with GetRootPart().GetAllBodies(). Or to get a body within a component (1st component in this case), go through the "Content" object: GetRootPart().Components[0].Content.Bodies. To get a component by name: comp = GetRootPart().GetComponents(comp_name)[0].
- An Aniket mentioned, bodies in SpaceClaim cannot exist without a name, so searching for bodies with blank names is not a sensible strategy.
July 5, 2023 at 6:20 pm
Sterling Butters
Subscriber@Aniket
Sorry, I did not clarify that I did not provide the body name (since it is variable/changing).Â
I was able to get it working with:
selection = Selection.Create([body for body in GetRootPart().GetAllBodies() if body.Parent.GetName() == ComponentName])
  faceLevel = False
  ViewHelper.SetObjectVisibility(selection, visibility, inSelectedView, faceLevel)Which I think implements the logic suggested by @mjmiddle
Thanks!
- The topic ‘Python API: Setting object visibility from selection’ is closed to new replies.
1891
1419
