August 20, 2024 at 1:44 pm
glab17
SubscriberHi I'm using ansys-fluent-core and I was trying to add local sizing on my geometry, in particular I want to set face size target and curvature, how can I do it?
August 20, 2024 at 2:33 pm
Forum ModeratorYou should find everything here  https://github.com/ansys/pyfluentÂ
August 20, 2024 at 2:37 pm
glab17
SubscriberI already watched there and I didn't find this option in the examples.
August 20, 2024 at 2:46 pm
Forum ModeratorHave you looked in the Ahmed body example? You may not find the exact command in one example and may need to pull information from different sources. There should be additional information in the PyFluent course on Learning.Â
August 21, 2024 at 11:14 am
glab17
SubscriberThank you I looked at the example and I managed to add local sizing. Can you please explain me how to set periodicity? It's not reported in any of the examples I have seen and the documentation is not so clear about what I have to put to set a translational periodicity with manual pick method.
August 21, 2024 at 12:34 pm
Forum ModeratorI don't have that information, the PyAnsys tools are currently only supported from the Github.
5799
