3D Design
3D Design
Proxy Server Issues
    • tim.dukes
      Hi Support,
      Can I send over the .ansys folder found in TEMP for you to take a look at regarding licensing privately.
      We have followed the instructions for proxy server - https://innovationspace.ansys.com/knowledge/forums/topic/proxy-server-configuration/?template=discovery but are still having issues with licensing. When doing a manual activation it connects to the server and then times out/denied.
      If you are able to look through the temp folder and let me know if there is anything else we can try.
      Best Regards,
      Tim Dukes
    • Rajeshwari Jadhav
      Hi Tim,
      Can you please share the screenshot of errors, first?
      Also launch Ansys Licensing Settings> click on feature in use tab and share a screenshot of it too.
      If needed, we can look at .ansys folder later.
