September 29, 2021 at 3:41 am
September 29, 2021 at 6:28 am
Subashni Ravichandran
Forum ModeratorHello M Rizuwan
I have not seen this issue before. Do you have any other Ansys products installed?
Can you try running the installation with "Run as Admin"?
Can you confirm that you have unzipped the installation files completely before attempting to install?
September 29, 2021 at 7:48 am
mrizuwan
SubscriberThe PC just been formatted, then I download the installer for Spaceclaim 2020 R1 (DISCOVERY_CADS_2020R1_WINX64.zip) here, Previous Versions . Next, I extract the file then proceed with Setup application. that’s how the problem happen
October 28, 2021 at 9:06 am
Can you please try
· delete the content of Windows folder called %temp%
· Go to %appdata%, rename the Windows folder called "Ansys" with a different name (for example Ansys_old)
· try running the installation again
- The topic ‘“Product not Found”’ is closed to new replies.
5679
1890
1419
