August 5, 2024 at 9:48 am
2401652014
SubscriberI want to use the Cyclic region function to calculate the vibration frequency of the whole disk through a sectoral bladed disk model.The calculation results include different frequencies under each node diameters. Then I extracted the mass matrix and stiffness matrix of the single sector blisk with the Cyclic Region boundary condition. Using the extracted matrix, I calculated its mode shape, which is the same as the mode shape under 0node diameter calculated by ansys. I want to know how to extract the stiffness matrix and mass matrix under other node diameters.
August 7, 2024 at 12:56 pm
dlooman
Ansys EmployeeThe difference between the stiffness matrix at different harmonic indices is the constraint equations created to enforce the harmonic index shape. These constraint equations are created during solution. A possible way to create a model for a harmonic index greater than 0 is to issue the command cycopt,hindex,N in a commands object. Then the system matrices will be only for harmonic index N.
6585
1311
