January 16, 2024 at 11:58 pm
January 22, 2024 at 12:05 pm
Praneeth
Ansys EmployeeHi,
Thank you for reaching out to the Ansys learning forum, your patience is much appreciated.
At what stage of the analysis this error is triggering? Please provide the details to help us serve you better. If you are trying to use HPC, then check whether you are using it within the limit allowed by your machine.
Best regards,
Praneeth.Â
January 23, 2024 at 12:05 am
biswash paudel
SubscriberHi Praneeth,
Thank you for your reply.
I encountered this error while simulating a chip model containing 5 antennas. Yes, I am using HPC. Could you please clarify what you mean by "using it within the limit"? I conducted the simulation on a machine equipped with 50 processors and 256 GB RAM.
January 23, 2024 at 9:26 am
Praneeth
Ansys EmployeeHi,
Did this occur during the adaptive passes stage of the analysis?
Please share the HPC options screenshots to help us serve you better.
Best regards,
Praneeth. -
January 23, 2024 at 10:13 am
January 23, 2024 at 10:59 am
Praneeth
Ansys EmployeeHi,
Please use 90% of RAM and try solving the model again.
Best regards,
Praneeth. -
January 23, 2024 at 12:12 pm
biswash paudel
SubscriberHi PraneethÂ
Thank you for the info.Â
I will run the simulation with 90% of RAM.Â
May i know what might be the reason to change from 99 to 90%?
Best regards,
Biswash Paudel
January 24, 2024 at 6:13 am
Praneeth
Ansys EmployeeHi Biswash,
This is a general recommendation to not load the RAM fully.Â
Best regards,
Praneeth. -
January 24, 2024 at 11:11 pm
biswash paudel
Thank you for clearing the doubt.
I am working on a chip model with 4 layers (10x10x1.35 mm^3): copper layer, Polyimide, Aluminium Nitride, and Aluminium.
I have placed 9 zigzag antennas (0.2mm length) in the polyimide layer at equidistant positions from each other.
I am looking for a transmission coefficient. What would be the best mesh setting and speed up for this type of simulation? Could you please help with this?
Best regards,
Biswash PaudelÂ
January 25, 2024 at 4:45 am
Praneeth
Did you try the HFSS 3D layout design type which is predominantly used for 3D models with small thickness like PCBs?
Best regards,
Praneeth. -
January 25, 2024 at 6:37 am
biswash paudel
No I use the HFSS for the design of whole structure and define individual layers.Â
Best regards,
Biswash Paudel
January 25, 2024 at 9:32 am
Praneeth
It is recommended to use the HFSS 3D layout for layered structures like PCBs.
Best regards,
Praneeth. -
January 26, 2024 at 4:29 am
biswash paudel
Subscriber -
February 25, 2024 at 3:47 pm
siva bala
Subscriberhi what is the reason for getting this error and how to resolve it
patch antenna (C:/Users/Administrator/Documents/Ansoft/)
 HFSSDesign1 (Terminal Network)
  [error] Solving adaptive frequency ..., process hf3d exited with code -1073741795. (08:47:53 PM  Feb 25, 2024)
  [error] Simulation completed with execution error on server: Local Machine. (08:48:14 PM  Feb 25, 2024)-
March 4, 2024 at 5:54 am
Praneeth
Ansys EmployeeHi,
Did you go through the recommendations mentioned in the thread?
Best regards,
Praneeth.
March 5, 2024 at 7:00 am
biswash paudel
SubscriberHi,Â
Yes, I relaxed the mesh setting, decrease the frequency sweep and applied domain decomposition solution with first order of basis function.Â
Best regards,
Biswash PaudelÂ
March 5, 2024 at 7:48 am
Praneeth
Thank you for confirming.
Best regards,
Praneeth.
- The topic ‘Process hf3d exited with code 1073740791’ is closed to new replies.
6359
