TAGGED: static-structural, structural, structure, workbench
February 4, 2021 at 9:37 am
suriyapracash
Subscriberwhat's the procedure for fatigue analysis of a shaft using a new material other than structural steel. How to input the values for SN curve for that shaft in engineering data?n#fatigueLife#fatigueAnalysisn -
February 8, 2021 at 4:27 pm
Aniket Chavan
Forum ModeratorGo to engineering data, by double-clicking on it.nTurn off Filter Engineering data in the upper left cornernin the toolbox under Life, you will find tools for SN curvendrag the required tool on the required material.n-AniketnHow to access Ansys help linksnGuidelines for Posting on Ansys Learning Forumn
- The topic ‘procedure for fatigue analysis of a shaft using a new material other than structural steel’ is closed to new replies.
