July 23, 2024 at 9:08 am
JOM
SubscriberProblems with SweepAroundAxis in 2D-Desing (about Z) and function “Create a 3D-Design”.
Version 2024R1 (also in 2023…)
I have drawn in 2D (about Z) an object like a washer in the origin of coordinate system and split the object (using plan YX).
1. If I did SweepAroundAxis with 360° (sweep axis Z) I get following error:
Maxwell2DDesign1 (Electrostatic, about Z)
[error] Parasolid Error: Failed in function PK_BODY_make_swept_body_2 with error PK_ERROR_sweep_failed. (09:21:53 AM Jun 07, 2024)
[error] Body could not be created for part because of invalid parameters to SweepAroundAxis operation. (09:21:53 AM Jun 07, 2024)
2. If I did SweepAroundAxis with 359° (sweep axis Z) its work but it is not what I like.
3. If I did SweepAroundAxis with 360° (sweep axis Z) and set the Number of Segments like 360 it works fine
But in version 2022R1, I can do case 1 without any Problems.
If I did it with “Create a 3D-Design.” I have the same errors
What I did wrong?
July 31, 2024 at 12:06 pm
Reshmi Raghavan
Ansys EmployeeHello Jens,
Please share the snapshot of the 2D model being used.
July 31, 2024 at 12:50 pm
- The topic ‘Problems with SweepAroundAxis in 2D-Desing (about Z) and function “Create a 3D-D’ is closed to new replies.
5984
1307
