LS Dyna
LS Dyna
Problem with working out the CESE LS-Dyna model
    • DENG
      I have a problem with working out the ICFD LS-Dyna model.When running the file, there is a problem with temperature not converging. How can this be resolved? How is the "cv   cp   c1    c2    pr "in the *CESE_EOS_IDEAL_GAS and *CESE_MAT_GAS keywords obtained, and how should the parameters of the mixed gas at different temperature and pressure be calculated?I would like to upload the complete document for you to see how to proceed?
      *CONTROL_TERMINATION
      $#  endtim    endcyc     dtmin    endeng    endmas     nosol
           0.001         0       0.0       0.01.000000E8         0
      *CONTROL_TIMESTEP
      $#  dtinit    tssfac      isdo    tslimt     dt2ms      lctm     erode     ms1st
      1.00000E-7       0.6         0       0.0       0.0         0         0         0
      *DATABASE_BINARY_D3DUMP
      $#    cycl      lcdt      beam     npltc    psetid
        100000.0         0         0         0         0
      *DATABASE_BINARY_D3PLOT
      $#      dt      lcdt      beam     npltc    psetid
      1.00000E-6         0         0         0         0
      *CESE_CONTROL_LIMITER
      $#   idlmt      alfa     beta       epsr
               0       2.0       1.0       0.5
      *CESE_CONTROL_SOLVER
      $#   icese     iflow     igeom    iframe
             200         1         3         0
      *CESE_CONTROL_TIMESTEP
      $#    iddt       cfl     dtint
               1       0.51.00000E-7
      *CESE_INITIAL_CHEMISTRY
      $#  chemid    compid
               5        11
      $#     uic       vic       wic     rhoic       pic       tic       hic
             0.0       0.0       0.0    16.708   2000000     300.0       0.0
      *CESE_INITIAL_CHEMISTRY_SET
      $#   setid    chemid    compid
             102         5        11
             0.0       0.0       0.0       1.03.000000E7    3000.0       0.0
      *CESE_PART
      $#     pid       mid     eosid
               2         1         1
      *CESE_BOUNDARY_NON_REFLECTIVE_SET
      $#    ssid
               1
      *CESE_EOS_IDEAL_GAS
      $#   eosid        cv        cp
               1     997.0    1418.0
      *CESE_MAT_GAS
      $#     mid        c1        c2        pr
               12.08600E-6    163.82      0.16
      *CHEMISTRY_CONTROL_FULL
      $#      id    errlim    rhomin      tmin
               5       0.0       0.0       0.0
      *CHEMISTRY_COMPOSITION
      $#      id   modelid
              11        10
      $#   molfr                                                               species
             2.0H2
             1.0O2
            3.76N2
      *CHEMISTRY_MODEL
      $# modelid    jacsel    errlim
              10         1       0.0
      det_n2.inp
      thermdyna.dat
      trandyna.dat
      *END
    • 15889756839
      I came across the same problem, anyone can help us?
    • Reno Genest
      Hello Deng,
      What error message are you getting? Which version of LS-DYNA are you using? You mean CESE and not ICFD correct?
      Note that Ansys employees are not allowed to upload and download files on the Ansys Forum. You can still post your model here and hopefully other users will chime in.
      Reno.
      • DENG
        Are these websites no longer accessible? Where should I look for these models?
    • Reno Genest
      Hello Deng,
      The LS-DYNA examples website is still available:
      https://www.dynaexamples.com/cese
      Although most of the content has been moved to lsdyna.ansys.com:
      https://lsdyna.ansys.com/knowledge-base/cese/cese-cese/
      I don't think the training class is available anymore.
      Reno.
