LS Dyna
LS Dyna
Problem with thermal analysis
    • javat33489
      Hi all.
      I am conducting a thermal analysis of drilling an SPG ram, using a model from LSTC. The mechanics work perfectly, everything is drilled, the voltages are normal. I want to enable thermal analysis.
      I connect cards:
      I'm using test parameters from my head (HC and TC).
      And INITIAL_THERMAL with a temperature of 22С.
      ___
      When calculating, I get the first entry in d3plot and look at it:
      temperature on the drill is 85С
      the temperature on the plate is simply horrid.
      ___
      After the start of the calculation I received the following warnings:
      Then I get an error and the calculation is completed:
      Why?
      Thank you.
    • Ram Gopisetti
      what version of dyna are you using.
      Any version 14 and higher should be good for SPG-Thermal studies.
      Cheers, Ram
      • javat33489
        I'm using the version from the 2023 kit.
        Tell me which cards should I show you? I would like to solve this error.
      • javat33489
        Help please
  • The topic ‘Problem with thermal analysis’ is closed to new replies.
