February 2, 2020 at 3:26 pm
Aerospace24
SubscriberHi guys, I'm trying to plot streamline around my airfoil after aerodynamics analysis (inviscid) at lift coefficient =0.
I've a problem in the post-processing when i try to plot streamline around the airfoil using CFX tool (Results) of ANSYS 19 R2. I've obtained that the streamline pass through the airfoil instead of surrounding it. How can I solve the problem ?
February 3, 2020 at 11:00 am
DrAmine
Ansys EmployeeCan you show velocity vectors?
February 3, 2020 at 11:12 am
February 3, 2020 at 12:02 pm
DrAmine
Ansys EmployeeInviscid= there is a slip at wall + no penetration.
February 3, 2020 at 12:09 pm
Aerospace24
SubscriberOk, Is this prompt to solve the streamlines problem or that one regarding the velocity vector on "perimeter"?
February 3, 2020 at 12:36 pm
DrAmine
Ansys EmployeeI do not understand your question: the suggestion to use vectors is just a workaround for you. If you think the behavior with streamlines is buggy you need to share more details about their creation and where you created the solution.
February 3, 2020 at 1:04 pm
Aerospace24
SubscriberI've obtained the solution using Fluent, it's an inviscid, incompressible analysis. I chose the angle of attack to obtain Cl=0(zero lift). Then I've used CFD-post for the results post-processing and there is the problem that I've showed in the first message of this discussion: streamlines passing through the airfoil.
Running other simulations, I did not have this problem. -
February 3, 2020 at 2:47 pm
DrAmine
Ansys EmployeeIf the streamlines in Fluent are looking fine just use them from Fluent or do export massless particle tracks from Fluent to CFD-Post if you prefer post-processing in Fluent. Also check if you can create surface streamlines in Post, as I assume you ran it 2D in Fluent.
February 11, 2020 at 11:38 am
Aerospace24
SubscriberHi everyone! I've solved the problem using the following commands: geometry->type>surface streamline.
February 11, 2020 at 11:56 am
DrAmine
Ansys EmployeeThanks for the update and sharing what worked with your case.
- The topic ‘Problem with streamline in CFX (results)’ is closed to new replies.
6450
