Photonics
Photonics
Problem with simulation of directional coupler
    • mukundsingh
      When simulating Directional coupler in EME solver for longer coupler lengths, Transmission exceeds 1, which should not happen. For longer coupling lengths the Transmission exceeds 1waveguide dimension (0.8um thick, 1um wide Silicon Nitride WG at 1550nm)
    • mukundsingh
      This is a Silicon nitride waveguide with 0.8um thickness and 1um width, simulated at 1550nm.
    • mukundsingh
      Green curve = Abs(s31)^2  : Through
      Red Curve= Abs(s21)^2 : Cross
  • The topic ‘Problem with simulation of directional coupler’ is closed to new replies.
