July 22, 2021 at 2:46 pm
Landervanhoye
SubscriberAfter installing the newest version of the Ansys Fluent software I made a calculation, but I couldn't open my results. I found a solution on: https://www.cfd-online.com/Forums/cfx/109708-postgui_ogl-exe-has-stopped-working.html.
I deleted the ".cfx" file and then I could open my results. But now I have to delete the file every time I make a new calculation.
Is there anything I can do to fix this problem?
July 26, 2021 at 6:21 pmSurya Deb
Ansys EmployeeHello,
Do you see any lock file (.lck) in your working folder?
If so, then you can delete those lock files and try again.
Regards SD
Viewing 1 reply thread- The topic ‘Problem with opening the result-app Ansys Fluent’ is closed to new replies.
Innovation SpaceTrending discussions- Unable to reopen setup and solution part on ansys workbench
- Ansys Student 2026 R1 – FlexNet Error -88,309 “System clock has been set back”
- How to solve “shell parts that are joined or merged together in their plane” ?
- Ansysのサイトにアクセスできません
- LS-PrePost How to export ICFD StreamLine data for all time states (CSV/JSON)?
Top Contributors-
