Problem with more than 1 outlet in the simulation
    • Saima Bukhat Khan
      Hi, I am running a simulation to evaluate the flow passing from inlet of chamber to the outlets. The chamber has three outlets and I have named them as outlet_1, outlet_2, outlet_3. When I import my mesh into FLUENT the oulets are named all together as 1 outlet and can't evaluate the mass flow out from individual outlets. What is the main reason of this problem and how can I solve it? Attaching image of my case for better understanding. Thanks.
    • Luca B.
      How did you create the faces name? Are you in Fluent meshing or in the geometry tool?
      Luca
    • Saima Bukhat Khan
      I created the mesh in ICEM and in ICEM we have option of naming the surfaces.
  • The topic ‘Problem with more than 1 outlet in the simulation’ is closed to new replies.
