May 5, 2018 at 11:42 am
jpvelez
SubscriberHello. I hope this email finds you very well!
I have a problem with the project at ansys fluent. After I finish the Mesh step, the setup page is disable and I really do not know why. How can I fix it? I tried update internet explorer and setup firewall but nothing was a solution. I had the same problem with ansys 19.0 and now with versión 18.2.
Thanks for your comments
May 5, 2018 at 3:27 pm
raul.raghav
SubscriberCan you open Fluent in serial instead of parallel and verify if that works?
May 6, 2018 at 11:05 am
Raef.Kobeissi
SubscriberCan you please attached the workbench project to inspect.
Regards
- The topic ‘Problem with fluid flow (fluent) project’ is closed to new replies.
1324
1087
