September 13, 2023 at 12:45 pm
dl
SubscriberFor the past few months, I and some of our customers have been experiencing the problem that as soon as we install the new version of the software, trying to start it after a few moments it crashes, disappears... Even after installing the provided patch.ÂThe only way to "fix" it is to go through the command prompt and force it open.ÂÂCan the alternative be found to give to our customers to solve this problem?ÂThank you in advance -
September 13, 2023 at 1:56 pm
Devendra Badgujar
Forum ModeratorHello Daniel,
This is a known issue with SpaceClaim 2023 R2 and is expected to be resolved soon. Only SpaceClaim is affected because its copy of Microsoft.Identity.Client.dll is slightly different than the copy used elsewhere.
The issue can be corrected by copying Microsoft.Identity.Client.dll from elsewhere to the scdm folder:
Copy from: $(AWP_ROOT232)\Subscription\bin\Win64\Microsoft.Identity.Client.dll
to: $(AWP_ROOT232)\scdm\Microsoft.Identity.Client.dllÂ
The file you want is 1,407 KB. Let me know if this helps.Â
DevendraÂ
September 13, 2023 at 2:17 pm
Devendra Badgujar
Forum ModeratorHello Daniel,Â
Just a note, this issue is with some subsciption users, and is expected to be resolved soon. Till then, please try using the command line options (run as admin for some) and the workaround mentioned above.Â
Thanks,Â
DevendraÂ
September 14, 2023 at 7:50 am
dl
SubscriberThank you Devendra,
I will try this procedure from now on, otherwise I will continue to use the prompt.
September 14, 2023 at 7:55 am
Devendra Badgujar
Forum ModeratorSounds good, thanks Daniel. Let us know if the workaround works for you.Â
DevendraÂ
- The topic ‘Problem when starting SpaceClaim 2023R2’ is closed to new replies.
