May 28, 2024 at 5:47 pm
javat33489
SubscriberHi all.I'm doing a calculation of a centrifugal pump wheel.I calculated one wheel, recorded the data on the outlet, and now I want to transfer it to the inlet to simulate the transfer of fluid speed from one wheel to the next.ÂWhen specifying reading to an inlet from a recorded outlet, a distortion occurs; when I try to shift the outlet to the inlet, instead of a circle of data I get a stripe:ÂHelp me please! Why is that? -
June 4, 2024 at 11:12 am
SRP
Ansys EmployeeHi,
The distortion you're experiencing when transferring data from the outlet to the inlet of a centrifugal pump wheel in your simulation could be due to several factors. It's important to ensure that the boundary conditions are set correctly and that the data is being interpreted and applied in the right manner.
July 2, 2024 at 2:20 pm
Forum Moderatorhttps://innovationspace.ansys.com/forum/forums/topic/problem-when-assigning-a-surface-from-a-recorded-profile-2/
- The topic ‘Problem when assigning a surface from a recorded profile’ is closed to new replies.
