May 5, 2025 at 7:01 pm
May 7, 2025 at 4:05 pm
Rajeshwari Jadhav
Forum ModeratorHi,
Can you let me know which version have you installed, academic or free student version?
If it's academic can you check if you are pointing to correct server? Also, it looks like a installation issue as "Analysis" is missing from toolbox
May 8, 2025 at 12:47 pm
emamk
SubscriberHi Raj
It is a full academic license. An agent from Ansys installed the license for me, so I do not expect an issue with the license installation.Any suggestions to check it?
June 13, 2025 at 12:42 pm
Rajeshwari Jadhav
Forum ModeratorHi,
License installation/updating (on server end) is different then pointing to the license from client end, launch Ansys Licensing Settings> click on floating and verify license name and port no. verify if it shows green check mark if hit on test> click on feature in use and check if all increments are visible.
4607
1510
1386
1209
