January 7, 2020 at 4:47 pm
sobhagumparti
SubscriberHello,
I am doing the fluent analysis. after meshing and moving on to the setup I get this message
Model information is incompatible with incoming mesh.
Found some missing and new zones in the mesh. To make mesh compatible with settings, please visit " match zone names" panel.......
what exactly its causing the error and what is the solution?
Please suggest me.
January 8, 2020 at 11:59 am
Forum ModeratorIt means some additional/different surfaces (labels) have been created in Meshing and Fluent's not sure what to do with them. This means you've already transferred a mesh into Fluent in the current workflow. What did you change?
January 14, 2020 at 10:50 pm
sobhagumparti
SubscriberMy model includes a typical flange connection with fluid and solid domains. After the meshing, when I took it to the setup module it took more contact regions/meshing zones(due to complex geometry) except the fluid and solid domains alone. So, I ignored the old contact/meshing zones by going to the Mesh operations command. it solved my problem and created the mesh. Is this the right way?
January 15, 2020 at 9:55 am
Forum ModeratorIf you've manually fixed all the issues then yes. If you've ignored some of the boundary settings I have no idea what's going to happen as it'll depend on what you didn't set up.
January 15, 2020 at 12:28 pm
sobhagumparti
So here it is what I did. This is the very first step after exporting the model to setup module after meshing. As, the setup was unable to match the incoming zones with the already created ones, i just clicked the "ignore the old ones" and "accept the new meshing zones". Didn't go to the boundary conditions yet.
January 15, 2020 at 1:31 pm
Forum ModeratorShould be OK then. I can't see any interface zones which is the most common cause of problems.
January 16, 2020 at 4:18 am
sobhagumparti
SubscriberThank you and lets see what happens when I input all the values and do the setup.
- The topic ‘Problem: “model information is incompatible with incoming mesh”’ is closed to new replies.
5159
1836
1387
1249
