August 15, 2018 at 12:01 pm
saivignesh786
Subscriber -
August 15, 2018 at 2:13 pm
peteroznewman
SubscriberDid you extract the zip file to a folder on your C: drive?
Did you turn off your Anti-Virus software?
Did you RMB on setup.exe to "Run as administrator"?
August 15, 2018 at 4:42 pm
August 15, 2018 at 6:03 pm
peteroznewman
SubscriberYou should install MS .NET Framework 4.6.2 yourself separately before you install ANSYS.
What folder name did you use for the ANSYS files extracted from the zip file? It should be something simple like C:install using only English characters.
August 16, 2018 at 6:05 am
DrAmine
Ansys EmployeeVer important is to install with explicit Admin rights. Moreover to install all prerequisites..
August 18, 2018 at 6:51 pm
saivignesh786
SubscriberHaiÂ
I installed MS.NET Framework 4.6.2 by myself and again I ran the installation process.
While installing I get a error in installing graphic driver in the temp files(tmp 7020,1528,4716&2168)
I have attached the error file during the installation process .
Thank you.Cheers
August 19, 2018 at 2:37 am
Ananth Narayan
SubscriberDo you have all specifications that ansys tells. -
August 20, 2018 at 4:35 pm
tsiriaks
Ansys Employee Hi saivignesh786@gmail.com,
Try renaming or deleting the folder C:Program FilesANSYS Inc before you attempt another installation.
Inside the installation package, there is a folder called 'prereq' , go in there and install all of those manually. Then, proceed with the software installation.
If that doesn't work, make sure you have write permission in C:Program FilesANSYS Inc and executable permission in C:Users
AppDataLocalTemp
Thank you,
Win
August 27, 2018 at 10:47 am
saivignesh786
SubscriberHi tsiriaks
I tried again by following all the procedures .
I tried again by installing all the files in the prereq folder prior to installation and again installed the setup file.
Now I can able to install and use it.
Thanks to you and everyone for the support throughout the time.
Cheers
Have a great time.
August 27, 2018 at 5:50 pm
- The topic ‘Problem in running ANSYS’ is closed to new replies.
5799
