3D Design
3D Design
Problem drawing
    • Roberto
      🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions
      Hello
      Can I send you a file privately?
      When I insert this file into the drawing, the file does not appear why? How do I fix the problem?
      Best Regards
    • Subashni Ravichandran
      Hello Roberto
      Thanks for sharing the files. I have removed them from the Forum.
      I'll look into it and get back to you
      Hello Roberto
      I checked the model shared and I observed that the Model works fine with Shaded and Wireframe geometry but does not show correctly in the drawing sheet when the geometry is set to Hidden lines and Hidden lines removed.
      I have shared my screenshots with you over email.
      I will check with my team here and investigate what could be the issue and file a bug as needed.
    • Roberto
      Hello Subashni
      When you have news let me know
      Best Regards
    • mg
      Hello Subashni
      Having same issue you described above, re the error with Hidden Line Removed selected, and still showing a hidden edge in the document window and when printed.  SC2021R1.  Shaded Mode displays ok.
Viewing 4 reply threads
  • The topic ‘Problem drawing’ is closed to new replies.
