Pretension steel cables in static structural analysis
    • mfronk3
      I would like to simulate a test frame that I am designing for an experiment. The main frame is made of aluminum and there is an 8x8 grid of steel wires. The bottoms of the 4 upright aluminum posts are fixed to the ground.
      In the experiment I am planning to use turnbuckles to pretension each steel wire to 10 lbF each. How can I model this load in an ANSYS static structural simulation?
      Thank you very much!
      Matt
      Hi Matt,
      I have learned a lot about cables under tension from jj77 who is knowledgeable about this, and may have something to add.
      A command called INISTATE creates an initial state of stress (or strain) in an element at the beginning of the solution. Look that up in the ANSYS Help system.
      Attached is a model of a long cable that has an initial stress applied so you can see how it is done.
      Since you want a force, you will have to calculate the stress that force will create in the cable.
      For a cable, Stress = Tension Force / Cross-sectional Area.
      Pay attention to the units once you start using Command Objects.
      Peter
      • Orlando Borgia
        Hi peteroznewman,
        I can't see the model thaou were talking about. Could you please send me that example, I'm interested of that topic too.
        Thank you
    • mfronk3
      Thank you--Is there a way to do it in Workbench?
      Yes, that was all done in Workbench.
    • mfronk3
      Ok, great. I'll give it a shot.
Viewing 4 reply threads
  • The topic ‘Pretension steel cables in static structural analysis’ is closed to new replies.
