October 11, 2019 at 12:44 pm
stranalyst
SubscriberHow can I run a prestressed modal analysis using its input file (ds.dat) using a HPC system/cluster? When I try to run, I get following error even I copied .rst and .rdb files to the directory in cluster where the batch file and input file exist. Should I add additional commands to the input file for modal analysis?
PERFORM A STATIC ANALYSIS
 RESTART WILL BE PERFORMED FOR THE ANALYSIS OF LINEAR PERTURBATION
 *** ERROR ***              CP =    7.360  TIME= 15:27:49
 During the multiframe restart process, neither the .RDB file nor the  Â
 .Rn files were found. Both files are required to perform the    Â
 multiframe restart for the linear perturbation analysis. You must use Â
 the RESCONTROL,LINEAR command in the prior base analysis. The     Â
 ANTYPE,,RESTART command is ignored.    -
October 16, 2019 at 5:13 am
Sandeep Medikonda
Ansys EmployeeTry using the /COPY command the way it was done in this verification manual:
October 21, 2019 at 2:25 pm
stranalyst
SubscriberThanks Sandeep for your help. I have solved the problem. I just realized that the name of static analysis result files needed for the restart and the jobname specified in the batch file should be identical. Otherwise, I get the error shown above.
- The topic ‘Prestressed Modal Analysis’ is closed to new replies.
1324
1087
