Ansys Products
Ansys Products
Pressure ‘spikes’ at inlet in straight tube under large, laminar flow
    • jfonken
      Hi all,
      I have a straight tube with a length of 10 cm and a diameter of 2 cm (simple representation of a vessel). At the inlet, I prescribe a patient specific inlet velocity and at the outlet I have a 3 element windkessel model. I tuned the WK parameters in such a way that outlet pressure is between 80 and 120 mmHg (10000/16000 Pa). However, I get these ‘spikes’ in pressure. My timestep was 1 ms, I am using the PISO pressure-velocity coupling method and I chose laminar flow.
      What we already tried:
      -        Lower the peak flow, this decreases the spikes suggesting that the difficulties mainly arise when the change in flow rate (increase or decrease) is large.
      -          Lower the timestep, this did not change the results.
      -          Decrease the mesh size, again no change in results.
      -          Tried pseudo-time method, no change in results.
      Adapt the WK parameters. Decreasing the compliance seems to improve the results, but then I did not get physiological pressures.
      • We're kind of lost now :(
      • Do any of you have suggestions on how to tackle this problem?
    • Essence
      Can you please show the inlet and outlet BCs? Maybe what and how exactly you applied at the BCs?
  • The topic ‘Pressure ‘spikes’ at inlet in straight tube under large, laminar flow’ is closed to new replies.
