December 2, 2018 at 8:31 am
arunprabhat12
Subscriber I have to apply pressure on truss line body members. Pressure is time varying blast triangular load. When i am applying line pressure through tabular instead of magnitude there is some error. But when using line pressure using magnitude then there is no error. So how can i apply a time varying pressure on line body?
December 2, 2018 at 5:15 pm
Sandeep Medikonda
Ansys EmployeeHi Arun,
 Please see this post on how to define an expression for pressure based on time.
Sandeep -
December 3, 2018 at 7:15 am
arunprabhat12
SubscriberThanks Sir
But when i am applying line pressure through tabular data, an error "Could not transfer loads and constraints to the solver" occurs.
But for pressure on surface body it is not showing any error
December 3, 2018 at 2:25 pm
Sandeep Medikonda
Ansys EmployeeArun, Can you explain with inline pictures as to what you are doing?
December 4, 2018 at 5:14 am
December 4, 2018 at 5:27 am
arunprabhat12
SubscriberBut in the static structural module this type error is not shown in applying line pressureÂ
December 4, 2018 at 3:14 pm
Sandeep Medikonda
Ansys EmployeeArun,
Looks like only the constant load is not supported for Explicit Dynamics. This is from the manual:
Loading Data Definition : Enter loading data using one of the following options.
Constant: Supported.
This is the only option supported for Explicit Dynamics.
Sandeep
Guidelines on the Student Community -
December 5, 2018 at 5:46 am
arunprabhat12
SubscriberThanks Sir I have checked the manual and it is written that tabular data is not supported for acceleration and line pressure in Explicit Dynamics. -
December 5, 2018 at 5:48 am
arunprabhat12
SubscriberIf I do the analysis of bridge under blast in Autodyn solver instead of work bench, will that be much helpful? -
December 5, 2018 at 11:59 pm
Sandeep Medikonda
Ansys EmployeeHi arun,
Yes, tabular data is supported for displacement, velocity, force, pressure BC. But not for acceleration, even in Autodyn GUI.
Sandeep
- The topic ‘Pressure on line body in explicit dynamics’ is closed to new replies.
3572
1188
1076
1063
952
