August 20, 2025 at 4:17 pm
PhilippeB
SubscriberHello,
LS-Prepost (all recent versions up to 4.13, normal and DP, windows) has issues when opening files in read only directories on windows shares.
More specifically:
- model files: when the input include INCLUDE_PATH_RELATIVE commands, the files are not found (and the model cannot be opened)
- opening binout files leads to crashes in recent versions. It works in old versions (4.7).
I tried various settings (do not write msg and cfile, use relative path) in the settings but without success.
Any solution? It would be great if it could be fixed. We use these a lot to access student results.
Thanks
Philippe
August 20, 2025 at 4:52 pm
igandiko
Ansys EmployeeCould you please try reset the configuration? You can either delete this file from %appdata% or launch LSPP, go to setting > configuration settings > reset.Â
Please also share how the *include card is defined in the k file. For binout, does the file work in other places (non read only folders)? Trying to understand if there is somehting in the file that lspp us unable to read or the issue is with the drive.Â
August 20, 2025 at 6:21 pm
PhilippeB
SubscriberThanks for your response. I tried it (deleted the folder) and surprisingly, yes it opens the files with the INCLUDE_PATH_RELATIVE without error.
However, as soon as I save an lsppconf file (even without changing any of the settings, leaving all defaults), it does not find the files again.
I tried to move the lsppconf to the subfolder and it is the same (error). Delete the lsppconf and it works.
So something seems wrong in the default lsppconf. I have put the file created by default without changing any of the option (I just redacted the path and username) below. What would be wrong in there?
Regarding keywords, it does it with all models we tested that have *INCLUDE_PATH_RELATIVE. Copying the files and they folders to a read/write folder on the same network share solves the problem. The first main file calling all others includes very few other keywords (several INCLUDE_PATH_RELATIVE, INCLUDE, DEFINE_TRANSFORMATION, INCLUDE_TRANSFORM essentially. In the specific file I used for the test, a CONSTRAINED_RIGID_BODIES, and a COMMENT). The error pops up at the first file not in the current directory.
The paths are written in unix style (../incl) as the share is on a linux cluster running the simulations.
Any suggestion?
Thanks
max_physical_memory =Â
texture = on
twoside_lighting = on
background_color  =   0.000,   0.000,   0.000
sky_color      =   0.418,   0.547,   0.867
ground_color    =   1.000,   1.000,   1.000
text_color     =   1.000,   1.000,   1.000
timestamp_color   =   1.000,   1.000,   1.000
mesh_color     =   0.000,   0.000,   0.000
label_color     =   1.000,   1.000,   1.000
hilite_color    =   0.500,   0.500,   0.500
outline_color    =   1.000,   1.000,   1.000
triad_color = Â Â 1.000, Â Â 1.000, Â Â 1.000
genpoint_color = Â Â 1.000, Â Â 1.000, Â Â 0.000
entity_color = Â Â 0.750, Â Â 0.750, Â Â 0.750
background_style  = fade
edgelwidth = 1
meshlwidth = 1
xycurvewidth = 1
fringe_light = on
plotunode = off
mesh_render = 0
outlining = edge
shade_mode = flat
highlight_node = on
result_onscreen = off
no_maxmin_elemnd = 5
highlight = on
popup_dialog = off
mat_ambient = 0.878430
mat_diffuse = 0.878430
mat_specular = 1.000000
mat_shininess = 38.400000
light_ambient.1 = Â Â 0.000, Â Â 0.000, Â Â 0.000
light_ambient.2 = Â Â 0.000, Â Â 0.000, Â Â 0.000
light_diffuse.1 = Â Â 0.600, Â Â 0.600, Â Â 0.600
light_diffuse.2 = Â Â 0.600, Â Â 0.600, Â Â 0.600
light_specular.1 = Â Â 0.300, Â Â 0.300, Â Â 0.300
light_specular.2 = Â Â 0.300, Â Â 0.300, Â Â 0.300
light_position.1 = Â Â 0.125, Â Â 0.125, Â Â 0.800, 135, 45
light_position.2 = Â -0.125, Â -0.125, Â -0.800, 270, 270
transparency_value = Â Â 0.850
mat_color.1 = Â Â 0.769, Â Â 0.004, Â Â 0.110
mat_color.2 = Â Â 0.251, Â Â 0.635, Â Â 0.843
mat_color.3 = Â Â 0.153, Â Â 0.510, Â Â 0.271
mat_color.4 = Â Â 0.824, Â Â 0.804, Â Â 0.000
mat_color.5 = Â Â 0.604, Â Â 0.333, Â Â 0.137
mat_color.6 = Â Â 0.761, Â Â 0.000, Â Â 0.227
mat_color.7 = Â Â 0.263, Â Â 0.392, Â Â 0.643
mat_color.8 = Â Â 0.200, Â Â 0.624, Â Â 0.376
mat_color.9 = Â Â 1.000, Â Â 0.922, Â Â 0.404
mat_color.10 = Â Â 0.659, Â Â 0.502, Â Â 0.310
mat_color.11 = Â Â 0.788, Â Â 0.161, Â Â 0.243
mat_color.12 = Â Â 0.659, Â Â 0.824, Â Â 0.847
mat_color.13 = Â Â 0.153, Â Â 0.604, Â Â 0.404
mat_color.14 = Â Â 0.808, Â Â 0.847, Â Â 0.106
mat_color.15 = Â Â 0.851, Â Â 0.643, Â Â 0.388
mat_color.16 = Â Â 0.667, Â Â 0.329, Â Â 0.525
mat_color.17 = Â Â 1.000, Â Â 0.647, Â Â 0.000
mat_color.18 = Â Â 1.000, Â Â 0.502, Â Â 0.502
mat_color.19 = Â Â 0.753, Â Â 0.502, Â Â 0.502
mat_color.20 = Â Â 0.502, Â Â 0.753, Â Â 0.502
mat_color.21 = Â Â 0.588, Â Â 0.349, Â Â 0.204
mat_color.22 = Â Â 0.753, Â Â 0.502, Â Â 0.753
mat_color.23 = Â Â 0.753, Â Â 0.753, Â Â 0.502
mat_color.24 = Â Â 0.502, Â Â 0.753, Â Â 0.753
mat_color.25 = Â Â 0.973, Â Â 0.667, Â Â 0.761
mat_color.26 = Â Â 0.682, Â Â 0.973, Â Â 0.369
mat_color.27 = Â Â 0.369, Â Â 0.694, Â Â 0.973
mat_color.28 = Â Â 0.973, Â Â 0.369, Â Â 0.596
mat_color.29 = Â Â 0.412, Â Â 1.000, Â Â 0.784
fringe_level = 10
fringecolor = 1 Â Â 0.000 Â Â 0.000 Â Â 1.000
fringecolor = 2 Â Â 0.000 Â Â 0.444 Â Â 1.000
fringecolor = 3 Â Â 0.000 Â Â 0.889 Â Â 1.000
fringecolor = 4 Â Â 0.000 Â Â 1.000 Â Â 0.667
fringecolor = 5 Â Â 0.000 Â Â 1.000 Â Â 0.222
fringecolor = 6 Â Â 0.222 Â Â 1.000 Â Â 0.000
fringecolor = 7 Â Â 0.667 Â Â 1.000 Â Â 0.000
fringecolor = 8 Â Â 1.000 Â Â 0.889 Â Â 0.000
fringecolor = 9 Â Â 1.000 Â Â 0.444 Â Â 0.000
fringecolor = 10 Â Â 1.000 Â Â 0.000 Â Â 0.000
sph_spherescale = Â Â 0.300
sph_spheredivs = 12
sph_spherestyle = 4
sph_fixedradius = 0
sph_hide_activated = 0
shrink_factor = Â Â 0.800
rotate_angle = Â Â 10.0
feature_angle = Â Â 30.0
default_light = Â Â 0.000, Â Â 0.600, Â Â 0.300
tooltip = on
mainmenu_on = right
mainwindow_pos_x = 204
mainwindow_pos_y = 32
mainwindow_w = 1066
mainwindow_h = 800
mainwindow_resize = 1
mainw_status = 0
plotwindow_x = 0
plotwindow_y = 0
xyplotlegend = on
init_path =Â
savefile_path =Â
read_cmd_file_path = 0
session_file = C:\Users\MYUSERNAME\lspost.cfile
message_file = C:\Users\MYUSERNAME\lspost.msg
add_lspost_cfile = off
append_maxnum = 10
append_cfile_index = 0
menubar_hotkey = on
show_animatedlg = on
fringe_ale_parts = on
fringe_auto_update = on
hidden_trace_line = off
displacement_scalefactor_rel = off
displacement_scalefactor = 1
reverse_recentorder = 0
scl_recent_num = 6
message = on
ic_gravity = 9.81
ic_timeunit = 1
drawscene = on
shell_ipt = maxima
split_constrain = 0
beam_tubesegs = 8
beam_prismon = off
beam_prismfast = off
beam_sizefactor = 500
beam_icst0_area_factor = 1
beam_icst0_intpt_color = off
beam3nd_on = off
ge_local_brickstrain = 0
fluid_outer_face = 1
animate_mode = 0
duplicate_action = 1
polygon_offset_factor = 1
polygon_offset_unit = 1
reference_coordinate_system_size = 50
override_screen_aspect = 0
fld_engstrain = 0
* 'fld_naddrg on' sets left side of t-n FLC to slope of 45 deg for true strain
* 'fld_naddrg off' sets left side of t-n FLC to eqn: fldo+em*(0.027254*em-1.1965) for Eng. strain
fld_naddrg45 = on
fld_tvalue = 0.8
fld_nvalue = 0.21
* 'fld_cracks_instability Cracks' sets forming failaure label to: Cracks
fld_cracks_label = Cracks
def_limit_flc = 0
def_allow_thinning = 0.3
def_safety_margin = 20
def_essential_thinning = 0.02
def_allow_thickening = 0.01
def_r_value = 1.82
def_failure = on
def_risk_fracture = on
def_severe_thinning = on
def_inadequate_stretch = on
def_wrinkle_tendency = on
def_wrinkles = on
def_wrinkle_slope = 1
* use a backslash at end of line to continue points list on next line
* ______10________20________30________40________50________60________70________80
def_flc = DEF 800521501
-0.3 0.909, -0.2 0.666, -0.1 0.475, 0 0.357, 0.1 0.44, \
0.2 0.493, 0.3 0.523, 0.4 0.547,Â
def_cracks_color    =   1.000,   0.000,   0.000
def_risk_cracks_color  =   1.000,   1.000,   0.000
def_thinning_color   =   1.000,   0.733,   0.000
def_stretch_color    =   0.400,   0.400,   0.400
def_good_color     =   0.000,   1.000,   0.000
def_wringle_tend_color = Â Â 0.000, Â Â 0.000, Â Â 1.000
def_wringle_color    =   1.000,   0.000,   1.000
def_hec_fld = 0
def_hec_lasercut = 0.8
def_hec_newpunch = 0.6
def_hec_wornpunch = 0.4
def_hec_maxstrain = 10
def_hec_minstrain = 5
def_hec_minor_maxstrain = 0
def_hec_minor_minstrain = -50
def_shift_safety_margin = 0.1
def_type_safety_margin = shift
def_type_limit_flc = %FLC
def_shellcheck_minsize = 3
def_shellcheck_maxsize = 30
def_shellcheck_aratio = 10
def_shellcheck_warpage = 10
def_shellcheck_minqangle = 45
def_shellcheck_maxqangle = 135
def_shellcheck_mintangle = 30
def_shellcheck_maxtangle = 120
def_shellcheck_taper = 0.7
def_shellcheck_skew = 45
def_shellcheck_jacobian = 0.6
def_shellcheck_charlength = 1
def_shellcheck_area = 5
def_shellcheck_featangle = 30
def_shellcheck_timestep = 1e-06
pscompression_mode = none
entitylabel_size = 4
cadlabel_size = 4
genselectlabel_size = 7
genselectpoint_size = 6
vector_line_width = 1
primitive_size = 0.6
occupant_list = 0
mesh_mode = 0
tmesh_max_elsize = 20
tmesh_min_elsize = 1
tmesh_chordal_dev = 0.15
tmesh_min_intang = 20
tmesh_gap_tol = 2.5
amesh_ave_elsize = 16
amesh_hole_size = 0
amesh_gap_tol = 2.5
data_change_confirm = 0
data_change_popup = 1
data_change_save = 0
keyword_version = 97113
keyword_parameter_format = 4
kwdairbag_outorder = 16
kwdale_outorder = 18
kwdboundary_outorder = 27
kwdcase_outorder = 4
kwdcese_outorder = 35
kwdchemistry_outorder = 40
kwdcomponent_outorder = 43
kwdcnstrnd_outorder = 46
kwdcontact_outorder = 15
kwdcontrol_outorder = 19
kwdd2r_outorder = 6
kwddamping_outorder = 2
kwddatabase_outorder = 58
kwddefine_outorder = 59
kwdelement_outorder = 21
kwdem_outorder = 3
kwdeos_outorder = 14
kwdfrequency_outorder = 20
kwdhrglass_outorder = 49
kwdicfd_outorder = 60
kwdinclude_outorder = 37
kwdinitial_outorder = 38
kwdintgrtn_outorder = 28
kwdintrfac_outorder = 39
kwdkeyword_outorder = 22
kwdload_outorder = 50
kwdmat_outorder = 55
kwdmesh_outorder = 45
kwdnode_outorder = 9
kwdparameter_outorder = 10
kwdpart_outorder = 41
kwdperturbation_outorder = 57
kwdrail_outorder = 31
kwdrgdwall_outorder = 13
kwdsection_outorder = 23
kwdsensor_outorder = 24
kwdset_outorder = 61
kwdstochastic_outorder = 1
kwdtermnton_outorder = 5
kwdtitle_outorder = 52
kwdtranslate_outorder = 11
kwduser_outorder = 42
kwd_output_order = 2
kwd_tree_font = 9
matdb_sort = Name
matdb_path =Â
printwait_delay = 300
printformat = jpg (format are:bmp,gif,jpg,pct,png,ps,tif,psimage,vrml2)
printpsfooter = on
movie_format = WMV/WMV (format are:GIF,JPEG,MOV/MPEG4,WMV/WMV,AVI/RLE,AVI/24BIT,AVI/MPEG2,AVI/MPEG4)
thickness_reduction_mode = 1
macro1 = macro1
macro2 = macro2
macro3 = macro3
model_size = small  (Options: xxhuge,xhuge,huge,large,medium,small)
autosave = 0Â
partgrp_autocenter = 0
fkey = 2 selpar
fkey = 3 xyplot
fkey = 4 measur
fkey = 5 ident
fkey = 6 ascii
fkey = 7 color
fkey = 8 blank
fkey = 9 fcomp
fkey = 11 switch
fkey = 12 widscrn
asksave = off
animate_speed = 0
recordorient = off
mount_point =Â
coord_angular_system = radian
mat_yielding_hvar = 0
networkdisk =Â
perfmessage = off
tempfile_path = C:\Users\MYUSERNAME\AppData\Local\Temp\LSPP\TMP\
autosave_proj_file_path =C:\Users\MYUSERNAME\AppData\Local\Temp\LSPP\TMP\
autoassign_matfile_path =
functionkey_path =Â
save_dosformat = Yes
working_directory =Â
use_working_directory = NO
feature_tree_pos_xy = 0,0
show_right_toolbar = 1
show_bottom_toolbar = 1
toolbar_font = 8
extra_toolbar = 0
view_angle = top
xyplot_page_col = 2
xyplot_page_row = 2
modelchk_ale = 0
metal_forming_gen = 1
bspline_continuity = 0
geom_read_tol_auto = 0
geom_read_tol_value = 0.010000
read_curve_color = 1
read_name = 1
read_popup_dialog = 1
read_popup_step_dialog = 1
geom_read_manifold = 0
read_iges_unit = MM
breakedge_tol = Â 30.0
auto_cleanup = 1
auto_check_unit = 1
auto_check_step_unit = 1
stitch_faces = 1 Â (options: 0-don't stitch, 1-stitch by part, 2-stitch whole model)
stitch_remove_free_vertices = 0
write_iges_mode = Faces
write_iges_unit = MM
load_blank_shape = 1
read_to_new_assembly = 1
copy_filename_to_assembly = 1
write_iges_author = *LST
write_iges_company = *******LST
write_iges_product = *******LSPrePost4.10********
geom_color_boundary_nd = Â 0.200, Â 0.200, Â 0.200
geom_color_mesh_preview = Â 1.000, Â 0.500, Â 0.500
geom_color_ref_axis = Â 1.000, Â 0.000, Â 0.000
geom_color_ref_plane = Â 0.000, Â 0.000, Â 1.000
geom_color_ref_point = Â 1.000, Â 1.000, Â 0.000
geom_color_ref_coord = Â 1.000, Â 1.000, Â 1.000
geom_color_point = Â 1.000, Â 1.000, Â 0.500
geom_color_vertex = Â 1.000, Â 0.000, Â 0.000
geom_color_sizevertex = 3
geom_color_edge_free = Â 0.000, Â 1.000, Â 1.000
geom_color_edge_independ = Â 1.000, Â 1.000, Â 0.000
geom_color_edge_share = Â 0.000, Â 0.000, Â 0.000
geom_color_edge_tshape = Â 1.000, Â 0.000, Â 1.000
geom_width_edge_free = 2
geom_width_edge_independ = 2
geom_width_edge_share = 2
geom_width_edge_tshape = 2
geom_color_face_iso_u = 2
geom_color_face_iso_v = 2
geom_color_faceiso = Â 0.800, Â 0.800, Â 0.800
geom_width_faceiso = 2
geom_color_face = Â 0.000, Â 1.000, Â 0.000
geom_color_preview_point =255,0,0,255
geom_color_preview_line =255,0,0,180
geom_color_preview_face =255,0,0,90
feature_tree_on = on
feature_tree_nodes_on = off
feature_tree_show_colorbox = on
feature_tree_headbar = on
feature_tree_geompart = off
feature_tree_assembly = on
feature_tree_post = on
feature_tree_keywordentity = on
feature_tree_automoveaftertitlechanged = on
feature_tree_color = Â 0.000, Â 1.875, Â 0.000
feature_tree_fontsize = 4
geom_sketch_snap_hv = 1
geom_sketch_snap_end = 1
geom_sketch_snap_tol = 8
geom_sketch_showgrid = 1
geom_sketch_majorgridspace = 1
geom_sketch_minorgridnum = 4
geom_sketch_majorgridnum = 10
geom_sketch_showcoordgrid = 0
geom_tessellation_accuracy = 0.005000
geom_curve_featurepoint = 1
dyna_exe_path =Â
auto_update_lspp = 1
last_check_data = 2025-08-20
check_frequency = 10
cfile_dialog = yes
particle_point_style = 1
filepath_openform = \\NETWORKPATH
filepath_preference = original
filepath_saveto = \\NETWORKPATH
filepath_workingdir = C:\Users\MYUSERNAME
fileopen_filter = 0 (0:default)
fileopenfilter_kwd = |dynain*;*.k;*.dyn;*.key;*.inf;*.kw;*.new
fileopenfilter_d3plot = |*d?plot*;*d?thdt*;*intfor*;*d3eigv*;*d3drlf*;*d3rms*;*.ptf;*.thf;*.iff;*fsifor*;*blstfor*;*d3psd*;*d3ssd;*d3acs;*d3part*
printopt_compression = 0
printopt_compressionmethod = 0
printopt_gammaadjust = 0
printopt_gammavalue = 1.000000
printopt_hd = 1
printopt_invert = 0
printopt_invalue = 0.000000
printopt_orientation = LANDSCAPE
printopt_paperheight = 11.000000
printopt_papersize = Letter
printopt_paperwidth = 8.500000
printopt_printmode = RGB
printopt_printtype = PNG
printopt_resolution = 300
printopt_target = FILE
printopt_transparentcolor = 0
printopt_transparent = 0
printopt_coverfix = 0
printopt_customw = 1920
printopt_customh = 1080
printopt_customka = 0
sysmisc_clockok = 0
sysmisc_poweron = 0
default_model_title =LS-DYNA keyword deck by LS-PrePost
right_text_icon = 1 Â (options:0-text,1-icon,2-text&icon)
bottom_text_icon = 1 Â (options:0-text,1-icon,2-text&icon)
max_number_fringe_labels = 0
show_part_name = off
show_results = off
noid_in_identify = off
reverse_fringe_color = 0
fringe_range_nodebased = 0
animate_ttb_show = 0
animate_ttb_icon = 0
animate_ttb_pos = -1000,-1000
animate_ttb_alpha = 40
animate_ttb_popup = 0
proxy_enable = 0
proxy_ipport = 0,0
proxy_userenable = 0
proxy_userpass = ,
beam_line_width = 1
beam_ref_location = on
deleted_nd_size = 3
double_legend = on
pick_center_ac = off
lsdyna_mpps_exe_file =Â
lsdyna_mppd_exe_file =Â
lsdyna_mpp_mpi =Â
lsdyna_que_sys = 0
lsdyna_current_jobs = 0
lsdyna_vm_proxy = 0
lsdyna_memory =Â
lsdyna_ncpu = 0
activelabel_font_size = 3
activelabel_line_width = 1
activelabel_color = Â 0.902, Â 0.902, Â 0.780
activelabel_line_color = Â 0.231, Â 0.231, Â 0.231
activelabel_background_color = Â 0.976, Â 0.494, Â 0.153
activelabel_show_whole_text = 0
activelabel_enable_backgroundcolor = 0
xyplot_output_type = 0
animate_ttb_fun_show = 1
animate_ttb_fun_icon = 1
animate_ttb_fun_position = -1000,-1000
animate_ttb_fun_alpha = 40
output_prin_direction = off
exp_format = on
decimal_digit_num = 2
legend_digit_num = 4
user_fringe_font_size = 4
user_title_font_size = 4
ident_exp_format = on
ident_decimal_num = 4
ident_exp_num = 4
show_mesh_and_outline = off
outline_ingore_transparet_parts = off
show_mat_axis = 1
stretch_image = 0
fit_image = 0
x_image = 0
y_image = 0
deg_image = 0
scalew_image = 0
scaleh_image = 0
scalec_image = 1
scale_flip_image = 0
render_mesa = 0
new_render = 2
core_render = 0
cfg_metalform = 0
output_file_ending = LF
popup_kwd_message = 1
decode_kwd_blankdef = 1
save_initinfo_2tf = 1
new_subsystem = 0
checkrealnumber_readkeyword = 0
check_labelid = 0
gen_sale_part = 0
exc_sale_part = 0
genmodelcheck_vars = 0
cmt_anchor = 0
refparts_for_actentities = 0
gl2ps_shading_ratio = 0
quad_area_measure_option = quad
fastprint_enable = 0
fastprint_currentpath = 1
fastprint_filepath =Â
fastprint_filename =Â
fastprint_cttime = 0
fastprint_capturewindow = 0
fastprint_clipboardcopy = 0
movie_mt = 1
kwdoutput_group = 1
extrapolate = 0
builddeletiondata = on
3d_drawbar_r1 = 2.75
3d_drawbar_rl1 = 2
3d_drawbar_r2 = 2.75
3d_drawbar_rl2 = 2
3d_drawbar_d1 = 8
3d_drawbar_d2 = 12
3d_drawbar_w1 = 10
3d_drawbar_w2 = 12
3d_drawbar_lt1 = 16
3d_drawbar_lt2 = 20
3d_drawbar_rt1 = 2
3d_drawbar_rt2 = 3
3d_drawbar_R3 = 3
3d_drawbar_A = 90
3d_drawbar_a = 90
spotwelding3dbase_r1 = 10
spotwelding3dbase_r2 = 0
spotwelding3dbase_r3 = 0
spotwelding3dbase_elenum = 24
spotwelding3dbase_x = 0
spotwelding3dbase_y = 0
spotwelding3dbase_z = 0
cfg_kwdpathseparator = 0
cfg_kwdrelativepath = 0
occupant_safety_gen = 0
app_plastics = 0
nvh_general = 0
apptool_gen = 0
dbl_dyna_exe_path =Â
des_sphere_scale = Â Â 1.000
des_sphere_divs = 12
des_sphere_style = 4
disp_show_title = 1
disp_show_legend = 1
disp_show_flegendlabel = on
disp_show_timestamp = 1
disp_show_nodeelement_detail = 1
disp_show_triad = 1
disp_show_fpsperf = 0
disp_show_featuretree = 1
disp_show_fringemin = 1
disp_show_fringemax = 1
disp_show_horizontal_legend = off
na_gray_fringe = 1
disp_show_bdc_distance = 0
disp_show_bdc_depth = 0
new_splitwin = 0
wintype_grid = 1
wintype_tick = 1
point_symbol = 1
wintype_frame = 1
wintype_legend = 0
wintype_autofit = 1
wintype_timeline = 0
wintype_invert = 0
wintype_maxgraph = 0
wintype_minmax = 0
wintype_average = 0
wintype_minorgrid = 1
wintype_cmap = 0
wintype_ontop = 0
icon_format = 24
contact_mcolor   =   0.000,   0.100,   1.000
contact_scolor   =   1.000,   0.100,   0.000
show_thickenedshell = on
smooth_thickenedshell = on
nodal_average_thickness = off
cfg_icfdpre = 0
cfg_subset = 0
cfg_report = 0
cfg_post = 0
cfg_mspost = 0
cfg_pre = 0
icfd_volmesh_elim_fast = off
iihs_nodes_order = Footwell, LeftToe, CenterToe, RightToe, BreakPedal, Left IP, Right IP, Door
iihs_color_range = 1 400 300 225 150
iihs_color_range = 2 400 300 225 150
iihs_color_range = 3 400 300 225 150
iihs_color_range = 4 400 300 225 150
iihs_color_range = 5 400 300 225 150
iihs_color_range = 6 400 150 100 50
iihs_color_range = 7 400 150 100 50
iihs_color_range = 8 400 150 100 50
nastran_nrb_merge = off
csi_filter_opt = 300
gen_sel_trans = 150
show_undo_redo_icon = 0
sort_part_info = 1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,0,0,0,0,1,0,0,0,0,0,0,0,0,0,
splane_line_width = 1
higher_order_element_vectors = 1
fringe_average = 1
outdyna_vname = 1
outdyna_freeformat = 0
outdyna_kwdtitle = 1
outdyna_parameter = 1
outdyna_comment = 1
outdyna_nondefault = 0
outdyna_refcheck = 0
outdyna_blankline = 0
outdyna_exactinput = 0
outdyna_checkundef = 0
outdyna_component = 0
outdyna_keepinputblank = 0
outdyna_keepinputlongfmt = 0
xpra_quality = 40
xyplot_attr_showalldigits = 0
cursor_4k = 0
movedock_dialog = 1
hidden_line_vector = 0
sectionforce_attached_parts = 0
coordinate_system_axis_scalefactor = 1
saej11 = 0
pythonhome = \
textbackdrop = off
fragment_info = 1,1,1,1,1,1,1,1,1,1,1,
output2console = 0
ansys_apip = 1
pbar = 1
multireadkwd = 0
ignorecomma = 0
switchmodel_ac = off
independent_model_view = off
minmeshlinesize = 0
sw_actborder = 1
bottomtbheight = 21
filterbits =Â
show_welcome = 1
3727
1323
1163
1090
1014
