February 27, 2023 at 6:08 am
Srinivasagam Venkataramanan
SubscriberHello Friends,
I am working on the simulation of a PCB board with ICs and a DC-DC converter. I have defined power dissipation(Watts) values for each chip and DC converter. PCB is placed inside an enclosure that acts as a Heat sink. I am interested in understanding how much power dissipated to the surroundings and on the frame. I have run steady state thermal analysis to determine the temperature rise. how to calculate power dissipation?
Thanks,
Srini
February 28, 2023 at 8:54 am
Pdev
Ansys EmployeeHello,
To calculate the power dissipation, you may select the "Heatflow" option for the particular geometry in the summary report.Â
Thank you,Pdev
- The topic ‘Power dissipation’ is closed to new replies.
1306
