Preprocessing
Preprocessing
Post processing : Wall Heat Flux of Helical Tube
    • Joanne
      I am simulating heat transfer in helical tube under constant wall temperature condition and I would like to calculate local heat transfer coefficient.
    • Surya Deb
      Are you using Fluent for this analysis? You can check the post processing variables, Wall Adjacent HTC, Surface HTC and yplus based HTC. For more details check this link [https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v202/en/flu_ug/flu_ug_fvdefs.html] Equations (42-60), (42-42) and (42-64).
      Regards SD
  • The topic ‘Post processing : Wall Heat Flux of Helical Tube’ is closed to new replies.
