Post Processing in transient analysis
    • murali
      This is the displacement probe plot for the free end of a cantilever beam subject to an initial displacement of 5e-3 m. I did this as a 2 step analysis. I have two questions:
      1. How should I adjust the analysis settings so that I get the displacement 5e-3 at time 0 (as it is not possible to keep the step end time as 0?) ? Or is there some way to adjust the plot once the analysis is done?
      2.  How do i get rid of the points on the curve so that I have a smooth curve?
      Thanks In advance.
    • erik.kostson
      Hi
      Answer to both questions is: copy the data from the displacement probe, and paste into excel and change the values as needed so they start from when you want – when plotting there you can choose a curve with no dots at the plotted values (so line only graph, dots only etc.).
      All the best
      Erik
      • murali
        Thanks you Erik.
  • The topic ‘Post Processing in transient analysis’ is closed to new replies.
