October 17, 2023 at 2:24 pm
Panagiotis Artemiou
SubscriberHello,
I am trying to post process some contours. I have channells inside of which is the fluid flow, and i want to present the velocity field in 3 different planes as shown in the image i am attaching.
However in the scale of the model, these planes are too close to each other.
Is there a way to move the planes a bit further away from each other for a better view? But maintain the velocity field of the original planes.
Essentially, I want to move them apart just for presentation purposes.
Thank you very much!
October 18, 2023 at 12:43 pm
Omkar Kulkarni
Ansys EmployeeHello,
The planes can be created only till the extent of the model. They can't be moved outside the boundaries of the model.Â
If size of the model is big I would suggest you to scale the model under the Domain tab and then setup the case.
I hope this helps.
Thanks,Omkar Kulkarni
- The topic ‘Post processing: explode view of contour planes’ is closed to new replies.
6219
