November 20, 2024 at 11:25 pmloant22Subscriber
is there a way to plot total deformation on y-axis and the length of a deformed beam of the x-axis in Static Structural? I used the path function snapped to mesh nodes to successfully plot normal stress against the beam length, and I would need a similar graph for the total deformation. The only posts I have found either discuss Force/Deformation graphs which is not what I'm looking for, or inserting an equation to create a similar graph, but I would need a graph based on the simulated total deformation.
Many thanks to whoever would be able to point me in right direction!
November 21, 2024 at 9:40 amDeepakAnsys Employee
Hi,Â
You can construct a path along the length of the beam, and then the scope total deformation to that path.
then use 'Chart' to plot the total deformation along the axial distance:
Refer link:Â
Path;Â
Making Charts and Tables in ANSYS Mechanical - PADT
Thanks,
Deepak
1081
447
390
225
201
