October 11, 2021 at 2:46 pm
gfav
SubscriberHello,
when running my simulation I get this error:
Port refinement, process hf3d error: Port 2 does not have a solved inside material on either side.. Please contact Ansys technical support.
What does it mean?
Thank you
October 11, 2021 at 5:16 pmPraneeth Munaga
Please provide more inputs to help us serve you better.
Kindly let us know what kind of simulation that you are doing and share snapshots of your model showing how you are assigning the port.
All the very best.
July 13, 2023 at 11:39 amTeja Y
SubscriberHello
when running my simulation I am getting this error,
Port refinement ,process hf3d error.Terminal Rectangle1_T1 on port1 contains a non-conducting edge. The terminal may need to be assigned manually..Please contact Ansys technical support.
What should I now?
Thank you
Viewing 2 reply threads- The topic ‘Port refinement, process hf3d error’ is closed to new replies.
5669
1890
1419
1304
