June 25, 2020 at 7:02 am
Sofia16
SubscriberHello,
In my model I am using a porous media zone. I would like to know what exactly are the conditions that Fluent imposes on the surface that there is between the fluid and the porous media. For that surface I selected "interior", like I saw in an Ansys Tutorial. I searched on the User's Guide but I didn't found what that implies physically (I mean like conditions imposed on pressures and velocities).
Best regards,
Sofia
June 25, 2020 at 1:39 pm
Forum ModeratorInterior means that there's a surface but it doesn't do anything. All zones must be bounded, on the outside of a domain this may be a wall or inlet; between two fluids it may be a wall (no flow) or interior (flow passes straight through).Â
June 25, 2020 at 1:41 pm
RK
Ansys EmployeeHello Sofia,Â
Can you please elaborate more on your question? Â
June 25, 2020 at 1:59 pm
Sofia16
SubscriberThank you for your replies.
What I would like to know is to know the mathematical condition between the two mediums.
Is there only the addition of a term in the momentum equations for the porous medium and nothing else?
Best regards,
Sofia
June 25, 2020 at 2:02 pm
RK
Ansys EmployeeYes, there is a source term accounted for in the momentum equation, which creates an artificial velocity along the porous medium.Â
Please refer to Section 7.2.3.2 :Â https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v201/en/flu_ug/flu_ug_sec_bc_porous_media.html?q=porous%20media
- The topic ‘Porous media: boundary condition on interface between porous media and fluid zone’ is closed to new replies.
6660
1313
