July 16, 2024 at 4:58 pm
Ruaraidh MacLennan
SubscriberHi, I am trying to run a simulation file I have produced on a local machine (v2023R1) on an HPC (v2022R2) but it seems that the dat file cannot be read when running on the HPC due to compatibility issues.
Is there any possible workaround for this that does not involve using the same software version?
Thank you
July 18, 2024 at 10:43 am
Prashanth
Ansys EmployeeHi, it is expected as the files are not backward compatible. It is better to prepare the setup again in polydata using the older version or use newer version in the cluster.
- The topic ‘Polyflow version compatibility for HPC’ is closed to new replies.
1885
1403
1262
