August 12, 2024 at 6:41 pm
milad.momtaz
SubscriberHello all,Â
I am trying to simulate a Generalized Newtonian Non-isothermal flow within a die, followed by a free surface.Â
After starting the solution (within 3-4 min), I get this error:Â"Internal error detected: unable to allocate enough memory."Â
The number of cells in mesh file is not that crazy (almost 1.5M). My system is using 8 core CPU with 32 GB RAM. Do you think I should upgrade my RAM or something else?ÂAppreciate your input.Â
Thanks,
August 13, 2024 at 2:09 pm
Prashanth
Ansys EmployeeHello,
You can use parallel solver upto 8 threads, reduce the mesh count to decerase solver memory, clear cached memory by closing background applications, run it on a cluster with larger memory etc..
