Polyflow (Blow molding) integration with thermal & CFX
    • hari.m.kalepu
      Hello everyone,
      I have a requirement to perform blow molding and heat the mold for some time, say 120sec using heater blocks and cool the mold using cooling blocks. Is this kind of simulation possible in Ansys using Polyflow and then transfer results to thermal. Also while moving the mold from heating machine to cooling machine it exposes to air for some time on the conveyer.
      Can anyone help me what are the component systems I can use in Ansys for this simulation?
      Regards
      Hari
    • Prashanth
      Hi
      Non-isothermal blow molding can be done using Polyflow. Check here for some tutorials on blow molding in Polyflow help page: https://ansyshelp.ansys.com/Views/Secured/corp/v222/en/poly_pftut/pt03.html
      You can then transfer the part to other solvers for further analysis.
      • hari.m.kalepu
        Hi Prasanth,
        Thank you for your reply and the useful link. I will try with this and lrt you know
        Regards
        Hari
    • Rahul
      Hi Hari,
      Please refer Polyflow to Mechanical Data Transfer (ansys.com) for transferring polyflow data to thermal and Using Imported Loads for One-Way FSI (ansys.com) for Mechanical- CFX coupling.
      Hope this helps you!
    • hari.m.kalepu
      Hi Rahul,
      These links are much helpful for data transfer and FSI. Thank you for hring
      Regards
      Hari
  • The topic ‘Polyflow (Blow molding) integration with thermal & CFX’ is closed to new replies.
