March 23, 2024 at 3:43 am
22111045
SubscriberI want to design pmdc generator but rmxprt has only pmdc motor. Is there any way i can design a pmdc generator.
March 26, 2024 at 8:35 pm
GLUO
Ansys EmployeeHi,
You can change the operation type between motor and generator in the analysis setup.
GL
March 27, 2024 at 6:17 pm
22111045
SubscriberTried but its not allowing me to change the option.Is it related to software purchase because I have student version of ansys rmxprt.
April 1, 2024 at 3:20 pm
HDLI
Ansys EmployeeHello Ashish Patil,
    Do you use machine type of "DC machine" or others? Could you show setup1 and machine type?
HD
April 4, 2024 at 6:12 pm
22111045
SubscriberI had selected machine type as pmdc motor but under analysis setup the operation type is not changing. It is by default set to motor and not changing to generator and also the on the extreme right of the analysis setup the read only box is checked which i am not able to de-select.
Tomorrow I will show you the setup1 and machine type.
Regards
April 15, 2024 at 2:06 pm
22111045
SubscriberPlease reply
April 15, 2024 at 3:49 pm
HDLI
Ansys EmployeeHello Ashish,
   Do you show machine type? Could you show your PMDC machine's image? If you could not find the setting of "generator" in Setup1 in your mahcine type template, it is a limit and you have to use Maxwell.
HDÂ
April 16, 2024 at 1:44 pm
April 17, 2024 at 12:50 pm
22111045
SubscriberAs said i have uploaded the images. Now please reply
April 17, 2024 at 12:52 pm
HDLI
    As I said previously, if you could not find the setting of "generator" in Setup1 in your mahcine type template, it is a limit and you have to use Maxwell.
HDLI
April 18, 2024 at 5:12 am
22111045
SubscriberÂ
Thank you for helping.
I have one more small doubt.
How to simulate maxwell design in generator or motor mode.
- The topic ‘PMDC Generator’ is closed to new replies.
5969
1307
