April 2, 2021 at 9:33 am
goldencatto
SubscriberHi, I am simulating a 60 degree sector mesh of diesel combustion in FLUENT and I need some help on plotting the graph for the heat release rate or rate of heat release as I could not seem to find a way to plot it under the report plot section. nThank you in advance. n -
April 2, 2021 at 3:27 pm
RK
Ansys EmployeeHello, nCan please be more descriptive on what you want regarding the plot so that we can assist you better? Thanks. n -
April 3, 2021 at 5:02 pm
goldencatto
SubscriberHello,nThank you for the reply.nI am trying to plot the heat energy that is released during combustion due to compression when the piston is reaching Top Dead Centre. I tried plotting using the Report Plot>Flux Report>Total Heat Transfer Rate but the graph gave me negative values. I also tried using total surface heat flux under facet and vertex averages but they also gave me negative values. My boundary conditions for my wall temperatures are set to 450K.n -
April 3, 2021 at 5:31 pm
YasserSelima
Subscribernegative value means the heat transfers out of the systemn
- The topic ‘Plotting Heat Release Rate Graph in Fluent’ is closed to new replies.
1311
