June 24, 2019 at 7:17 am
June 24, 2019 at 9:12 am
Forum ModeratorI'm guessing that air density is constant. Mach Number is available for compressible materials. Otherwise use a Custom Field Function and divide velocity by the speed of sound to show Mach Number for your system.
June 25, 2019 at 1:28 am
jainanup27
SubscriberDensity is approximately constant (Incompressible ideal gas) Where can I find custom field function?
Thanks,
Anup
June 25, 2019 at 11:04 am
Forum ModeratorUnder the User Defined tab.
April 3, 2023 at 4:56 pm
cfdasdf
SubscriberWhat if I am using Ideal-gas model and still the Mach Number does not appear in CFD-Post? (Mach number is also checked in the Data File Quantities Option)
- The topic ‘Plot Mach Number Contours’ is closed to new replies.
